jparker66's avatar
jparker66
Blue Line push on sewer hose
Has anyone used the Blue Line push on sewer hose? My hands are not what they used to be and it is very hard to twist on connectors. This soundl like a solution to my problem.
Thanks
James
  • We use a plastic spanner, works great and cost little. Think it's a Rhino product, two to a package so you have a good grip when putting two lengths together.
  • ejmorgan wrote:
    I've been using them for many years without any problems.
    Ed
    I bought one of these at O'relies auto and it made a big difference. Peter
  • I used the Blue Line hoses for 7+ years until the hose got a hole in it. The fittings can be much harder to connect/disconnect than standard bayonet connections. If you have issues with strength in your hands I would stay away from the Blue Line system.
  • This might be a solution for you...it's a push on "cam lock" system rather than the twist on connection...
    Google: Waste Master Sewer Hose. (you can also convert the hoses you already have to this system for much less money. That's what I did)
  • We have them, but they can be hard to get apart since they rely on the friction fit for non-leakage. If you get them tight enough to not leak they can be kind of hard to twist apart. Personally I think they're harder to get apart than the regular twist-lock kind.
  • I've been using them for many years without any problems.
    Ed
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
