rexlion's avatar
rexlion
Blue Ox Sway Pro, how it functions against sway
I've been reading about and looking at pictures of the Blue Ox Sway Pro. And I've read some of the recent threads here that discuss this hitch. Blue Ox describes the sway control as a "caster effect" but their advertising does not elucidate beyond that one descriptive phrase.
Near as I can figure it out, this caster effect is caused by the spring bar sockets being offset from the swivel point (the ball). On the other end of each bar, a chain runs upward to the trailer frame. If the trailer should sway to one side, the end of the bar on that side will travel farther along the frame in the direction of the trailer, and since the chain's length is fixed it causes the bar tension to climb, and all of this exerts a push on this side. Meanwhile the opposite (pull) is occurring on the other side. Do I understand this correctly so far?
Assuming I've stated the forces at work with reasonable accuracy, it seems to me that the push-pull forces continue to be exerted (albeit in a declining amount of force) as the trailer's angle to the tow vehicle once again approaches 180 degrees (i.e., straightens out).
The problem I see with this is the fact that an object in motion tends to stay in motion. Consider the pendulum: as it climbs to one side, the force of gravity exerts a downward pull and the pendulum slows, reverses course, and swings toward 'straight down'... but the pendulum does not stop there. It continues to arc upward in the opposite direction. Taking this example to the Sway Pro, it seems as though the trailer's motion back to 180 degrees has little or nothing stopping it from continuing its swing in the opposite direction. As the trailer sways the opposite way, the Sway Pro again exerts the push-pull force in an increasing measure until the TT's sideways momentum is stopped... and is again pushed & pulled in the other direction where it again has unchecked momentum to go beyond 180 degrees.
Without some dampening force (such as friction) to slow the momentum and avoid the pendulum effect, I don't see how the Sway Pro can truly be an effective anti-sway hitch. If someone has a different or better concept of the physics involved, I'm open to hear it (I'm not a mechanical engineer, unlike my son).
As for people's experiences while using the Blue Ox Sway Pro, I fully realize that most users are happy with it (but meanwhile, some users have experienced sway with it...and felt strongly that it was properly adjusted, too). I think that an analogy might be drawn to the many people who, over the years, have happily and successfully towed without any sway control whatsoever; in other words: it worked fine, right up until the one day when conditions were just right, and then (surprise!!) it didn't work.
Comments? Questions? Curse words? :D
  • I think you will find that it is not a true pendulum, in that there is spring pressure applied whenever the trailer is off the center line. This causes a self centering effect and the "pendulum" energy is dissipated with that spring compression.
    I don't have one but have been reading mixed reviews that has kept me from buying one. I like the idea of eliminating the noisy, troublesome friction control of both the popular and inexpensive hitches.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 28, 2025
