schlep1967
Jul 22, 2020Nomad
tompla wrote:
I have a 40 ft Class A MH. I am going to pull a trailer with electric brakes. Curt makes the Echo mobile Trailer break controller that plugs into the 7-way plugin on the back of the coach and then you plug the trailer brake into that Echo Device. The device is managed thru Blue Tooth as an app on your phone. I am concerned if Blue tooth will have a strong enough signal when my phone is with me on the dash. Has anyone had any experience with this type of set-up?
Your phone is not controlling the brakes. It is manged by your phone. Managed as in you can use your phone to adjust the amount of brake applied. Like adjusting the dial on a regular brake controller. When you plug in the 7-way plugin and apply the brakes the plugin/brake controllers inertia reader will adjust the amount of voltage applied to the brakes. I'm sure it would use the settings previously applied if the bluetooth signal is lost.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
