JRscooby
Jul 23, 2020Explorer II
JRscooby wrote:schlep1967 wrote:
Your phone is not controlling the brakes. It is manged by your phone. Managed as in you can use your phone to adjust the amount of brake applied. Like adjusting the dial on a regular brake controller. When you plug in the 7-way plugin and apply the brakes the plugin/brake controllers inertia reader will adjust the amount of voltage applied to the brakes. I'm sure it would use the settings previously applied if the bluetooth signal is lost.
I might be OK with this, but need to understand Why? I hook up to a trailer, and adjust the settings for that trailer. If I only pulled 1 trailer, never need to adjust. Why would I richard around with a phone to make adjustments?
valhalla360 wrote:
Because everything is better with Bluetooth...
I assume sarcasm?
The primary thing is to adjust the brake controller settings thru the phone. That should be OK as you shouldn't need to change those often and worst case, you should be able to take the phone and walk to the back while parked and make an adjustment. They say that once set, it remembers the settings if the connection is lost.
How do you people adjust your controller? I start on a low traffic street, make repeated stops until dialed in up to about 25 MPH. After that, normal driving, I adjust little at a time, go to far, back off, until it feels best. Then I record the settings for next time I pull that trailer. While I might want to apply brakes while near trailer wheels to trouble-shoot, not to adjust controller.
But it also has the manual trailer brake application thru the phone. If you do any driving in the mountains, this is a deal breaker for me as there are times, I will use the trailer brakes independently and I don't want to find out it's not connecting when it fails to connect.
Shortly after I retired, Feds determined for a driver of commercial vehicle to talk on a phone, he had to use a hands free device. I disagreed because it is the mind distracted, not the hand busy that is the issue. OTOH, my brake controller is mounted. If I need to apply trailer brake, I don't need to look for the control, I want to know where it is, and it is connected.
BTW, if at highway speed, and a tire blows, we are told not to brake. If pulling a trailer, get on the trailer brakes. If it is a trailer tire, will not matter, you will not loose control anyway. If it is a TV tire, the extra pull will hold you straight, and drop speed.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
