Community Alumni
Mar 29, 2014Not applicable
It is a royal PIA. I have the same type of trailer that uses a 5-pin connector. If your TV is not wired with a 5-pin connection, you must insert that metal thingy in the slot to be able to back up without having the brakes lock up. I use duct tape to hold it in place.
If your TV has a 7-pin connection, you can buy an adapter and you won't have to worry about locking up your brakes when backing up.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 27, 2026
