frederickn's avatar
frederickn
bounce in trl when parked
We have a 28ft pull trl and when ever we stop and I level the unit it always still has a bounce in it when we move around. It's level and the front and rear stabilizers are down and firm to the ground. I also have the metal expanding chocks that go between the tires. I have one slide out and use supports . Anyone got ideas on what to do. Been rving for a while. The trl is two years old.
  • larry barnhart wrote:
    You can screw a scissor jack to the frame in front of the front tires and steady the suspension.
    chevman
    X2.
    I did this. Now I have 6 scissors jacks on my 26 ft. TT. No more bouncing. Usually have to tighten the jacks a tiny bit after a day when parked on softer ground (especially when wet) as some settling occurs.
    Ed
  • You can screw a scissor jack to the frame in front of the front tires and steady the suspension.
    chevman
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
