hvac wrote:
campigloo wrote:
hvac wrote:
I don't think the gen y hitch would work with the Andersen system. Appears you would not have any sway control.
It should work just fine with Anderson. His bounce is up and down motion. Sway is side to side motion. One has nothing to do with the other.
To op, you could also try adding StableLoads to your truck. It essentially adds an additional leaf to your rear suspension. It worked nicely on mine.
Ok, but sway with Andersen is in the ball and friction material inside the hitch. Wouldn't sway be lost?
It shouldn’t have any affect because the Gen y mounts between the receiver tube and the hitch head and has no side to side movement. I’m not good at attaching links but if you go to their web site it’ll quickly make way more sense than I can explain.
