spud1957
May 22, 2015Explorer
cbenn wrote:
Let me save you some time, on your Ford if you can stop the trailer with the controller and not with the brake pedal your TBC pressure transducer is out, it is located directly under your master cylinder, there are 2 sensors there, the front one is more for the brakes/cruise control, the second one is the transducer for trailer brakes, ford carries them at a whopping $154.00, go on line and should find them for around $100.00. Hope this helps you out.
I think you are referring to the built in Ford TBC? The OP has an after market Prodigy controller.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
