mowermech, wrote:
In a panic stop at 60 MPH your motorhome will travel almost 200 feet before your foot hits the brake pedal.
Hi mowermech,
With all do respect, and I really enjoy your informative posts, this line doesn't sound quite right. That would correlate to a response time of over 2.2 seconds. While I guess that's not out of the realm of possibility, I would think most (sorry to use that word again! LOL) of us would do a bit better than that. But, maybe not?
But your point is still valid. At highway speeds, these things cover a lot of ground quickly and in a panic situation you want everything possible on your side to bring things to a safe, controlled stop, perhaps even going beyond what a state might require.
OP, check the owner's manual of your motorhome, if you have it. I know ours had a statement stating something along the lines that anything towed over 2,000 lbs. (it might have been 1,500 lbs....I forget) required brakes. With that statement in the manual, I felt that regardless of what the laws were, a lawyer would have a pretty easy time of making it appear I was negligent if I didn't have brakes on our towed vehicle. By the way, we tow a Honda Odyssey and it weighs in just about 4,480 lbs., give or take. So it is a bit heavier than yours. I definitely CAN tell a difference in braking with and without the TOAD brakes engaged, and am glad that I have the braking system I do. So far, I don't know for sure if I've actually needed that toad brakes, but there was one panic stop incident that was pretty close...and it would've been a lot closer had the Ody's brakes not been applied.
Also, if you haven't had the rig weighed fully loaded and ready to travel, I'd suggest you do that. Then you'll know your actual operating weights.
Safe travels,
~Rick
