Is your trailer brakes working for you... Use the manual slide switch and see if that stops you and trailer without pushing the brake pedal on the truck...
I do this quick test everytime I hook up before I leave my neighbor hood...
You can use your boy scout compass up close to each wheel when the brakes are applied and see if the needle deflects on each wheel... I think the Ford OEM brake controller however has to be moving above 10MPH before the Electric brakes get DC Voltages from using the Truck Brake Pedal. Works anytime using the manual slider switch... My 2010 Ford OEM Brake controller does this at any rate...
My brakes make a low tone noise when the magnet is activated.
It is a US DOT Safety law that your brakes and on-board trailer battery are working when being towed over public roads... This is an enforceable law... This is required for the Emergency break-away trailer switch being operational...
Kinda of important to have working trailer brakes I would think...
The Ford shop can tell you if the OEM Brake Controller is working properly for a $90 minimum shop fee... A boy scout compass is just a couple of dollars...
Roy Ken
