JaycoJohnExplorerMar 21, 2021brake problemI'm setting up my 2006 CR-V for flat towing behind my motorhome. Installing Invisibrake supplemental braking system. Hooked up all the wiring and hardware. Tapped into the vacuum lines. Had done every...Show More
JaycoJohnExplorerMar 21, 2021Will now shift out of park. I forgot to plug brake light switch back in. But will still NOT move.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
Related Contentbraking problemBrake problemSlide Brake ProblemTrailer brake problem?Atwood water heater problem
