I'm setting up my 2006 CR-V for flat towing behind my motorhome. Installing Invisibrake supplemental braking system. Hooked up all the wiring and hardware. Tapped into the vacuum lines. Had done every...
Called Roadmaster (couldn't call until Monday) yesterday and they suggested I make sure the brake light switch was adjusted correctly. I didn't even know it was adjustable. I took it out to check wiring for monitor and inserted it back in all the way which pushed down on the brake pedal. Simply fix. One of those "feel like an idiot" situations, but easy fix anyway.
thanks for the suggestions.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
