JaycoJohnExplorerMar 21, 2021brake problemI'm setting up my 2006 CR-V for flat towing behind my motorhome. Installing Invisibrake supplemental braking system. Hooked up all the wiring and hardware. Tapped into the vacuum lines. Had done every...Show More
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: May 28, 2026
Related Contentbraking problemBrake problemTrailer brake problem?Slide Brake ProblemAtwood water heater problem
