Liltippy's avatar
Liltippy
Brake system choice
I have a 27' Born Free on a Ford 450. Planning to tow a 2007 Chevy HHR that weighs 3200#. Looking for recomendations on braking system. I have not purchased a tow bar, so would the ReadyBrake system be a possibility?
Looking for something simple and inexpensive if possible.
Thanks
  • DougE wrote:
    Here I go again... How about a short car hauler trailer? It comes with electric brakes, gets rid of needing to add complexity to a HHR and lessens the wear & tear on the HHR. Put a hitch on the HHR so you can move the trailer around when you drop it from the Born Free. Then you have a trailer to use for other chores as well. There's a couple of steep grades in the country where you might want to drop the HHR off the trailer and have the wife follow you. Easy to do.
    While I agree with the trailer idea, one must be realistic. An E450 chassis will either have a 3500 lb towing capacity or 5000 lb. capacity.
    Even an aluminum trailer plus a 3200 pound car would exceed the 3500 lb capacity, and how many of us can afford even a good used aluminum car hauler?
    A steel trailer will come close to the 5000 lb. capacity.
    Would I, personally, worry about it? Probably not. After all, I towed my Jeep (see sig.) with an E350 based Class C.
    Would I state that somebody else should not be concerned? Of course not.
    To answer the OP question, the ReadyBrute integrated towbar/braking system is an excellent choice, especially with the breakaway system added.
    Good luck.
  • Here I go again... How about a short car hauler trailer? It comes with electric brakes, gets rid of needing to add complexity to a HHR and lessens the wear & tear on the HHR. Put a hitch on the HHR so you can move the trailer around when you drop it from the Born Free. Then you have a trailer to use for other chores as well. There's a couple of steep grades in the country where you might want to drop the HHR off the trailer and have the wife follow you. Easy to do.
  • I wouldn't use anything else.. Have used Blue Ox with brake unit inside toad. Ready Brake is easy to hook-up and unhook, No battery drain on toad....
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
