Dutch_12078
Apr 03, 2017Explorer III
As far as removing power from the car itself, it doesn't matter which cable you disconnect from the battery. It sounds like your dealer installed the Stay-n-Play power so it's directly wired to the battery positive terminal, so as long as you don't disturb that connection and leave the negative connected, it'll work ok. Just install a battery switch on the positive side that disconnects everything else.
