4x4ord's avatar
4x4ord
Explorer III
May 28, 2023
Brakes are Broke
I’ve got disc brakes on my fiver …. they stop the trailer great but something seems broke. If I set my truck to electric over hydraulic I get a “trailer disconnected “ warning if I apply the brakes momentarily then release and reapply the brakes …. release again and reapply the brakes again. It happens every time on the third application. When the ‘trailer disconnected “ message is displayed the brakes continue to function as expected. I’ve got two identical 2022 F350s and both trucks behave the same way when hooked to that trailer (the only trailer I have with electric over hydraulic brakes). Another bit of interesting observation is that if I set my brake controller to “electric” rather than “electric over hydraulic” I don’t get the message. What do you all think? Is there a problem with my trailer or Ford’s software? The first time I noticed this was pulling the trailer with my 2022 ….. but it’s possible something happened to the fiver since my “21 was hooked to it. For instance I did accidentally leave the emergency brake away unplugged for about an hour which kept the hydraulic pump running nonstop which in turn got the brake fluid and wiring extremely hot.
  • 4x4ord's avatar
    4x4ord
    Explorer III
    ford truck guy wrote:
    Check woth Ford.. my son in law has a 2022 and had the same thing.. They had to go into the computer system and wipe out the memory and reflash the IBC..
    Ford had a recall on the brake control module. I brought my truck in and had it done but performing the recall made no difference. Our second F350 was built after the recall. Anyway I think I'll try hooking up a good ground wire as was suggested and if that makes no difference I'll give the dealer a call.
  • Check woth Ford.. my son in law has a 2022 and had the same thing.. They had to go into the computer system and wipe out the memory and reflash the IBC..
  • Admittedly no idea. But I would probably get a wire, even an old set of jumper cables and make a temporary ground. Just connect from a bolt or bare piece of steel on the trailer to a bolt on the truck and try again. It doesn't cost anything and only takes a minute to eliminate a grounding problem.
Looking for advice before your next adventure? Look no further.25,107 PostsLatest Activity: Jan 29, 2025
