klutchdust
Jun 06, 2019Explorer II
One thing I learned about the ready-brake that was used on my 08 wrangler was the cable needed to be adjusted when both vehicles were on a flat and stable surface. I once adjusted it when the toad was in the garage and the MH was on a slight incline, oh boy.
Once it is adjusted I never had a reason to adjust it again. i simply lifted the cable to check the allowable slack and went on my way. When first installed I mounted a camera to record the brake pedal travel and drove around the neighborhood.
Now, your issue may be with the hitch sliding properly into itself. One of my ready-brakes had a slight weld chip inside the tube, they advised me to push the plunger down inside the tube to check travel and it worked flawlessly.
As far as the comment concerning the resistance of the tube sliding into itself. Surge brakes on trailers have been around for a very long time. We have a contractors trailer with a million miles on it that has been abused and it slides in and out just fine with little to no maintenance.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
