wjschill's avatar
wjschill
Braking system required?
Would a dingy that weighs 2600lbs. need a supplemental braking system for Class A towing, with a 5000lb. rating. I know it would be safer, but is there a minimum weight that is acceptable?
Thanks
  • In NYS any trailer rated 2,000 lbs needs to have brakes (the last time I checked the NTDIT web site)
  • Do not believe the companies that manufacture auxiliary braking devices. Check with your state police. Many states do not have requirements for a towed motor vehicle which are not considered trailers.
    Verify in your rig's owners manual towing capacity. Do not go by what is stamped on hitch or ball mount.
    Thanks
    something to check before you decide. the brakes on your MH may be engineered for the gross vehicle weight rating of the MH only. check with the chassis mfg. if the MH is close to its GVWR (which it probably is) then I would absolutely add an aux braking system. Me? I'd add it anyway cuz you never know when that next panic stop is gonna happen.
  • Each state has it’s own rules. Some use actual weight limits, some use a %. Of the towing vehicle. Some require break away switch no matter weight. Considering you are risking other peoples lives in a breakaway situation, think about the possible consequences of saving a few dollars.
    Also, when in an emergency stopping situation, I have never heard any complaints about having extra braking available it is your choice but know that the laws vary and your insurance may not cover you if you are in violation of a state law.
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: Feb 21, 2025
