westend
Oct 25, 2014Explorer
darsben wrote:Or continuity to frame ground.
Since you know nothing about the wire the first thing would be to put a VOM on the end of the wire and to ground see if you have a voltage on the wire.
Likely suspects for the loose end would be electric jack, breakaway brake system, stabilizers, accessory lighting.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
