Alabama_Jim's avatar
Alabama_Jim
Bug Prevention While in Storage
What are the best ways to prevent bugs from entering your RV while in storage?
  • Thanks for the input. I used home bug spray and loaded it anyhere something touched the ground. I also put put traps inside. Hope this does the trick.
  • Bumpyroad wrote:
    you cannot keep stink bugs out unless you put masking tape on all window/door/edges, vent lids, etc. when I traded in my class A I had to rent a front end loader to get them all out. :)
    bumpy
    Just hang a bat or two in there....no more stink bugs. :R
  • you cannot keep stink bugs out unless you put masking tape on all window/door/edges, vent lids, etc. when I traded in my class A I had to rent a front end loader to get them all out. :)
    bumpy
  • Take all food items out - including spices. Don't leave crumbs on the floor, take out the bedding. Even with slides closed, bugs can get in. Take a look at where your pipes pass through the bottom membrane. They usually spray cheap foam that disintegrates over time.
  • Keep it closed with the slides in and screens on the vents.
    Use something like "Home Defense Max" or "Bayer Advanced" bug spray around anything that touches the ground.
    Keep an eye on the air conditioner covers to make sure wasps aren't building nests.
    General stuff like that.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
