Tom_Barb's avatar
Tom_Barb
Buying land to camp.
We are contemplating buying a small parcel of land to snow bird to.
just large enough to place a pad, electrical 50 amp plug, and a storage shed.
what state would you suggest? warm please. we have kids in Texas -- so?
and please give a reason.
    Which state is really not problem. You would have to check with each and every County that you find land in to see if they ALLOW RV's to be parked on an empty lot. In my experience most do not. You migh find some that might let you park it on the property but will not let you live in it.
    Heck it's nearly impossible to buy a house anywhere that will allow you to just park your RV on the property!
    I'm sure you'll get a lot of responses from people here who do it anyway illegally. Which is fine unless you get caught and it usually is someone in the area that will turn you in.
    And the electrical? If you do find a lot out in the boonies. You have to figure in the cost of bringing in electric AND....when they come out and find out it is an RV? Most power companies won't/can't give you electric.
    I found a house that had a deeded RV pad with electric and sewer. But when I called to have the electric hooked up once they saw it was for an RV they said no because the codes had changed since the previous owner owned the land.
    Not to be a debbie downer but I tried and tried and never did find an empty lot that allowed just an RV and power. And I was looking in just about all the Southern states!
    You can 'buy' a lot in RV resort's but they are costly.
  • Arizona.
    Fuel, propane, and food are fairly inexpensive.
    Property taxes are cheap, especially on land with no structure on it.
    Permits for sewer and electric, depending on the County, are pretty cheap, and pretty easily obtained.
    Depending again, on the County you are in, Medicare supplements are less expensive, and plentiful.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
