Hdultra8965's avatar
Hdultra8965
B&W And 2015 Chevrolet 3500 ISSUES
I have had my turnover ball installed by a dealer. I purchased the companion slider to go with it as well. There seems to be a problem whereas the companion at the rear toward the tailgate. The companion sticks up about a 1/2 in toward the rear, not laying flat in the bed. The dealer told me that it would lay flat once the trailer was connected. Well that did not happen. The companion pushed in the bed and cut the metal in the bed. Now I have to big dents and cuts in my brand new 2015 Chevrolet 3500HD. No one has offered a solution to the problem, Dealer, B&W etc. B&W said that I have to sand the pads on the bottom is unacceptable. B&W knows there is a problem with the 2015 Chevrolet trucks beds not being level. Tech at B&W did not offer any solutions to me or the dealer. Why was there no documentation to the dealers about this issue. Not even the biggest dealer in the country knew there was a issue with the 2015 Chevrolet models. So I cannot haul anything until someone figures this out. I can't risk anymore damage to my Brand new Truck. At this point I'm out of options. This review is not intended to bash B&W. I just have to get this resolved in order to use my truck as intended. So would recommend this product to a friend, Not to someone with a 2015 Chevrolet at this time. But would recommend it to people who do not have 2015 Chevrolet. At this time. This was the post I made to B&W..
Has anyone with the 2015 Chevrolet had any issues with this setup. Thanks in advance.
COMPANION SLIDER 5TH WHEEL HITCH
  • I agree that the pads should be flipped.
    As far being able to shim the main hitch point. I dont think it is possible without having to drill out the holes in the frame. Everything is a tight fit.
  • The pads under the hitch should be turned over, so the flat part of pad fills the bed indent. The beveled side now downward is meant for a bed with the indents closer together.
    This may not fix the whole problem, but would help, and is what the instructions show, if the installer would have looked at them.
    Jerry
  • So, the bed itself isn't flat so the hitch can't sit flat on it, right? weird.
    Shim it?
  • You can see the dent right behind the pad. And also the metal is cut from the pad, right underneath.
    Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
  • Here are some photos. Keep in mind that the front of the companion had sunk into the bed at the front of the base Already. I have only put about 50 miles on it.
  • Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
