Cummins12V98
Feb 05, 2015Explorer III
Just look at them side by side! B&W has 1" thick machined jaws that fit the kingpin perfectly. The PullRite has 1/2" laminated jaw that won't fit as good as the B&W.
B&W has a simple no question latching system. The B&W RVK3600 is top quality and is made specifically to fit your factory puck system. No picture frame adapter is required that just adds more connection points. They are quiet with no rattles.
Ask anyone that has a B&W and have used other non air ride hitches their opinion and they will tell you B&W is by far the best out there. No goofy handle to try to operate or color coding to tell you if you are latched.
With the B&W hitching is so simple. With the hitch and kingpin plates touching, and the handle closed and locked, visually see the 1" thick jaws closed around the kingpin there is no question if you are hitched or not. It's that simple.
You have the best truck so be sure to get the best hitch to go along with it!
I have the RVK3600 sitting in my shop waiting on the arrival of my 15 RAM.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
