shannon62's avatar
shannon62
Camping at 27 degrees.
We are new fulltimers,with 2007 bounder class a 38v. We are trying to stick around sw p.a. till thanksgiving, they are calling for low around 27 degrees. We have ducted heat,2 furnaces,with supposed basement heat so say's owners manual. I am going to disconnect from shore water and just use fresh tank,keep heat on 70,leave luggage lights on (1156) in wet storage,leave gray water open as always & empty black then shut and add antifreeze.Should that be good enough ?Thanks Shannon.
  • It sounds like you are doing everything right. One thing that can get you are air leaks. Go out at night and with the lights on in the basement, look for any light escaping. Get those holes blocked with rags or tape. If the air leak is close to a water line it can easily cause it to freeze.
  • Manuals are often generic so verify what they state and check that everything works. For 2 weeks out best to plan for lower temps. Open all cabinets and areas inside with water pipes. Doubtful that low wattage 1156 bulbs willl provide adequate heat. Consider 120V lights.
Looking for advice before your next adventure? Look no further.25,156 PostsLatest Activity: Aug 13, 2025
