MFL
Apr 21, 2021Nomad II
EASY.RIDER wrote:
I should have added, with the tow pkg added it is rated capable of towing 7500lbs. however I am very concerned weather this truck can handle my load going up steep inclines and also going down hill. This same pkg has been used in the 2019,2020 and now the 2021 models. Tom
IMO, this setup would not be a good choice for mountain towing. Not saying won't work! The length of inclines may make a difference, as well as the sharp curves, often encountered in MT towing, which makes slowing a necessity.
With the turbo, good power should be available, unless a lengthy climb of 3-5 miles caused excess heat, due to a small engine working hard.
On the long steep downhills, you will not get good engine braking from a small engine (4 cyl, or V6). Again, from my experience in MT towing, most times, these ups/downs are full of sharp curves, which require very well maintained trailer brakes, and yes, you need to use them properly. I hope everyone knows to not ride the brake pedal in this type scenario.
Jerry
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
