valhalla360
Apr 21, 2021Navigator
mkirsch wrote:
What is all this malarkey about "engine braking?"
I've owned several full size pickup trucks, all with small block V8's except my '03 Chevy 3500, and NOT A SINGLE ONE OF THEM could hold ITSELF back on any sort of incline using the engine alone. Downshift downshift downshift, rev rev rev, faster faster faster... I ALWAYS had to control the descent with brakes.
The ONLY truck I've ever owned that would control itself on a hill is the '03 Chevy 3500 with the 8.1L and Allison. Turn on tow haul mode, hold the brakes for 3 seconds, and the hill would have to be EXTREMELY steep to need brakes, and then only a brief tap. However, the truck still needs frequent application of brakes to maintain speed with any sort of trailer behind.
Unless you're throwing out a ship's anchor at the top of the hill, you're using brakes.
Obviously, it will depend on a few factors (total weight, engine size & grade).
I was shocked how good the V10 in our 2008 is as an engine brake (F250 towing around 7500lb trailer).
Sure if we are doing a 8-10% downgrade, I have to hit the brakes every so often but far less than if we just relied on the wheel brakes.
With a 4-5% grade, I generally don't have to touch the brake pedal at all.
Of course a smaller engine will provide less engine braking but it should still be your first line of defense as it can provide it's braking power pretty much constantly and indefinitely.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
