JRscooby
Apr 22, 2021Explorer II
mkirsch wrote:
What is all this malarkey about "engine braking?"
I've owned several full size pickup trucks, all with small block V8's except my '03 Chevy 3500, and NOT A SINGLE ONE OF THEM could hold ITSELF back on any sort of incline using the engine alone. Downshift downshift downshift, rev rev rev, faster faster faster... I ALWAYS had to control the descent with brakes.
The ONLY truck I've ever owned that would control itself on a hill is the '03 Chevy 3500 with the 8.1L and Allison. Turn on tow haul mode, hold the brakes for 3 seconds, and the hill would have to be EXTREMELY steep to need brakes, and then only a brief tap. However, the truck still needs frequent application of brakes to maintain speed with any sort of trailer behind.
Unless you're throwing out a ship's anchor at the top of the hill, you're using brakes.
Just for snots, on a stop you make every day, slip into neutral as you start to stop. Bet you need more brake than normal.
jshupe wrote:
That's my experience with gas engines, not diesels with exhaust brakes. My current truck does a great job managing 25K+ GCW on 6-7% grades without having to use the brakes. The EB in my Duramax was considerably weaker, but still much better than any gas engine I've used.
One thing many don't understand how much the high-speed rearends have reduced the effectiveness of engine braking.
I would still like to see a side by side comparison, same gears/loads/displacement, the whoa power of restricting air going in the engine compared to restricting the air coming out.
I will never forget the first load on the first diesel I bought. That 6-71 did not have any add-ons to help slow the load.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
