trail-explorer
Aug 30, 2016Explorer II
wnjj wrote:ScottG wrote:
Yes, it can.
You want the attitude of the trailer level or slightly nose low.
Mine was ever so slightly nose high and I could induce a bit of sway at high speed.
OP was talking about the receiver itself, not the hitch. He's using a larger drop drawbar to compensate.
If the ball is at the same height as before, there should be no difference. The force effectively acts at the same point against the tow vehicle.
There's something else causing your issues.
x2. Sounds like ball height is the same (or close to the same), since you mention needing a hitch with more drop.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
