blt2ski
Jun 01, 2017Moderator
Going back in posts. IF you still have the P tires you quoted about. THOSE ARE, better than std P rated tires, in that they take upwards of 42 lbs of PSI, a standard p tire only can handle 32-36 lbs. Those are a bit heavier duty, but not as good as a C rated LT tire at 45 lbs in the same size. Not sure you need E or 10 ply rated tires for your rig. You will only need about 45 lbs in them, so they will only be as good as a C rated tire at 45 lbs from a total load standpoint, and you will pay more for them.
At the end of the day, sounds like things have gelled together, which is the whole point of what you want things to do.
Marty
Marty
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
