time2roll
Aug 09, 2018Nomad
MetalGator wrote:Well certainly get a voltage reading before and during slide operation.
One of the reasons I suspect the batteries is on our last trip, when I turned on the inverter, instead of showing the voltage it showed three zeros. I turned it on and off and still 000. I started the generator and then turned on the inverter and it showed a little over 13 volts. I spoke with a local RV tech and he said it sounded like a battery issue. When the slide starts moving out the motors sound normal and it extends fine. But after a few seconds I hear both motors start to slow down and it seems to struggle. Doesn't do it every time but only the last two trips.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
