QCMan
Oct 18, 2023Nomad III
If you want to make things easier, dig down around that pipe and you will find a clean out cover. Unscrew the cover and put a PVC fitting in so you can raise it to just below grade and put a fitting for a 4" plug to screw in. Then you can use standard sewer fittings even if you are using a macerator. The clean out plug may never be used and if it needs to be used all you have to do is unscrew your extension. By keeping it just below grade it will be your secret.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
