- Golden_HVACExplorerI have always jacked up my RV by placing a bottle jack under the spring mount on the axle. However some axles are not as strong as others, and trailer frames can be particularly weak due to manufactures who spec really thin metal to keep the weight (well cost) down to a minimum.
I have heard of frame damage on some frames. You have to be careful not to put to much weight on a single point of the frame while lifting it. That said, I would consider it safer to have more than lifting point. So you might jack up the unit by the frame a bit, and support that with jack stands or perhaps a stack of 4X4.
While supporting the frame, then jack up a axles one at a time, and then put the tires on blocks, then put the boards in that you wanted to.
I was also camped on sand, and that area was subject to flooding (it was like a creek running under my RV at times) and my tires sunk into the sand, as well as the 6" diameter bigfoot jacks. I had to raise the jacks, then put more dirt under the jacks and 30" long 2X10"s. Then I could lift the whole RV (with the jacks) and then put more dirt under the tires. I was lucky that my Ford frame is strong enough to not bend at all!
Good luck,
Fred. - Water-BugExplorer IIHow old are the tires? Were they 5 years old before you parked it or brand new?
EDIT The tires should be stamped with a manufacture datecode. - Happy_Camper3ExplorerI guess I can, but would prefer to jack it up.
By the way, I haven't moved it in two years, are the tires still good ? or do they need to be replaced before I take it on the road ? I was hoping to take it to a few campgrounds this year.
Do I just check for cracks, and if I don't have any, I"m good ? - MarkTwainExplorer
Happy.Camper wrote:
Hello, my camper, which is actually a toy hauler ( if that makes a difference) has been sitting in the same spot for about 2 years now.
Its starting to lean to one side..
Can I jack up one side, by the frame, just enough to slide a 4ft 12x2 board under the tires ? to level it out.
How much risk, is there of bending the frame ?
Is there a reason not to just hook up your trailer move it 5' forward to backward and then put you 12x2 boards down and then just pull the trailer up on the the 2x12. Job done:):) Looking at your picture, I might have some concern about the ground under your trailer, dosent look too hard or level as far as trying to jacking up trailer by frame.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 21, 2026
