stevennlv
Oct 29, 2019Explorer
4x4van wrote:
To the OP; what do you mean by "DSI fault"?
There is a little red light next to the switch that is labeled "DSI FLT". When things do not work as intended that light comes on.
When I search for that I get a bunch of returns on a DSI Fault that tell me to clean various parts of the system (combustion chamber, etc). When that does not fix it there are a million suggestions on troubleshooting, like turn the stove on before the water heater to "clear air out of the line" or to turn off the electric heater and either bleed the tank or wait for it to cool before turning on the gas water heater b/c if the water is already hot the thermostat/control-board(?) will prevent the gas from igniting if everything is already hot, etc, etc, etc, etc, etc, etc, etc, etc, etc, etc, etc.
Last year I had to fiddle with all that junk for about a day, maybe two and the fault finally went away and everything worked for a year.
As I get deeper into describing everything, people asking me questions here and I continue to research based on info folks have suggested here I too am starting to think the problems is at some point in the gas supply.
So the new regulator and pig tails will be here tomorrow. I ordered them first thing this morning.
Wish me luck, b/c if this don't fix it I'm going to have to take it to the shop.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
