crasster's avatar
crasster
Explorer II
Jan 24, 2020
Can I tow this and how will it feel?
Okay here are the specs. I "think" I'm figuring this right.
2017 Chevy Express 15 passenger van. 1LT. 6.0L engine.
GCWR 16,000
GVWR 9,600
Van Weight 6,129
Passengers total weight: 920 Pounds
RV weight: 6,660 Pounds
Battery + Propane: 125 pounds
Weight Distribution Hitch: 100 pounds
1 Seat removed from van (extra space) = +80 pounds (gained)
Clothes, towels, blankets, pillows, fluff: 100 pounds
Food: 30 pounds
Extension cords, some hand tools, fix a flat, parts: 100 pounds
A few pots, pans, dishes, etc.: 50 pounds
Outdoors stuff like camp chairs, bug candles, etc: 50 pounds
Bathroom stuff, tooth brushes, etc.: 15 pounds
Misc whatever: 200 pounds
If fill 30 gals of freshwater 30 X 8 = 240 pounds
So I did the Math Subtracting everything (and adding one thing) from my GCWR.
I'd be left with:
+1361 pounds until I hit (what I understand??) to be my limit, or +1601 without a tank full of fresh water.
I also don't plan to travel much with full gray or black tanks.
So question time.
Am I missing something here?
If truly I still have 1361 Pounds left, should that be a "breeze" for my van to tow this trailer + all passengers & stuff?
What about grades? Will it struggle/white knuckle time (or will it handle it well) **note in mountains I will ABSOLUTELY not carry fresh water or gray/black water on mountains so +1601 until GCWR of 16000.
All opinions, suggestions, etc. appreciated. I just would like to know what I'm in for. Thanks!!
  • Next question, would I be pushing it if I bought a 7200 pound trailer rather than the 6660 pound one as I mentioned earlier?
    So this would be 821 pounds left for GCWR Max.
    I think I have plenty of payload for Tongue weight.
    What my main concern is will I be struggling greatly up grades/down grades? I don't mind if I feel it for sure, I just mind if I'm gonna have doubts if I can make it over a 6% grade.
    I do have the M5 / M4 option on my van to keep it out of high gear.
    Plus I have a tow button which does.... umm... what it does. :)
    If it would struggle on mountain grades, how would it do on flats and "basic" hills?
    Thanks!
  • aftermath wrote:
    I think your numbers are correct IF you want to stay below your GCWR of 16,000. But, that is not the first number you should focus on.
    Your stated GVWR is 9600 while your van only weighs 6129. Subracting these leaves you with 3471 which is a very healthy payload capacity. Payload capacity is where most of us get into trouble. Large trailers connected to half ton trucks usually violate the payload numbers before they violate the GCWR.
    Ok, with 3471 to play with start subracting things that will go in the van, not things that go in the trailer. 920 for the family, 100 lbs for the hitch itself and you are down to 2451 which is still a large number. You can add back the 80 pounds for taking out the seat and now you have 2531. What you failed to account for is the hitch weight of the trailer. Think about that. Drop the hitch on the ball and you are adding weight to the van. Even if you had a HW of 1200 lbs you would still be good to go. So, as someone earlier posted, you should not have any trouble with your set up.
    One last thing. With today's TVs, engines have improved vastly. Some think that as long as you can go fast and make it over the hills you are good to go. When and if you go over your payload capacities, you are pushing the GVRW numbers. These are there based on the ability of the axles to carry the weight safely and the ability of the TV to stop safely. Stay within the ratings and you will minimize the wear and tear of the components on your TV.
    Thanks a bunch for this informative answer!! :)
  • I think your numbers are correct IF you want to stay below your GCWR of 16,000. But, that is not the first number you should focus on.
  • The crucial spec you didn't mention is- what does the Van's owners manual say Re: towing capacity.
    GCWR 16,000
    GVWR 9,600
    Van Weight 6,129
    …. Thanks!!
    Are you planning to tow this with the RV in your signature??
  • agwill wrote:
    I have 2015 one ton 15 passenger van also and no problem with 9,000 pound trailer.
    Any trouble on steep hills/mountains by chance?
  • I have 2015 one ton 15 passenger van also and no problem with 9,000 pound trailer.
  • “without a tank full of fresh water.“
    You’ll be unable to stay at bunches of beautiful dry campgrounds if you don’t have any fresh water. Why cut it so close? Barely within weight maximums? That’s not fun.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
