RoyB
Apr 19, 2015Explorer III
If you are going to work on the 12VDC cabling turn off the converter/charger unit and pull the battery terminals.
Both the CONVERTER/CHARGER unit and the BATTERY TERMINALS feed the same point on the 12VDC Distribution wiring panel.
Here is an simplified 30AMP WIRING BLOCK diagram that may be of some help for you..
My present used 12VDc UPGRADE looks like this which I am in the process of starting a bigger and better upgrade to get more AHs and use some solar panels for daytime charging of the batteries. My game plan here is to use my 255AH battey bank to run all the 120VAC items we want to have from an INVERTER and 12VDC items direct connected to the battery bank. Then will use my 2KW Honda Generator connecected to the trailer shore power cable each morning around 8AM when allowed to run my generator here on the East side of the US to recharge the battery banks back up to their 90% charge state using the on-board PD9260C Converter/charger unit running off the generator 120VAC. This takes around three hours using the SMART MODE charging techniques...
Once re-charged to the 90% charge state then we are good for the next day/night run off the batteries.
Roy Ken
Roy Ken
