luberhill's avatar
luberhill
Can I wait a week to winterize
Ok it’s supposed to hit maybe 32 at night for a couple nights but back up in the 40s during the day
My coach IS inside my polebarn and I doubt it will get below the outside temp but ???
We want to use it a couple more times so I really don’t want to winterize just yet
Then we leave with it for the south
  • If it were me, I'd drain the hot water heater and fresh water tank, I'd blow the water out of the lines, and drop some anti-freeze down the drains. Better safe than sorry and it should only take 5 - 10 minutes to blow out the water.
    -Michael
  • How will that keep lower pipes from freezing ?? Is it ok to run itbinside my barn
  • Turn your heat on, set at 40. You likely use little propane and this will keep your basement from freezing temps keeping your pipes and such ok.
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 26, 2025
