sch911
Jul 04, 2014Explorer
OK so I am a Jeep Engineer....
6,200 lb towing capacity, 1,270 lb payload - These are just marketing ratings, your vehicles actual ratings will vary.
2,540 lb front & 2340 lb rear per CAT scale - You easily meet the axle ratings.
OK so this means that your JGC weighs 4880# (2540+2340).
The GVWR is 6500 so your JGC's payload (6500-4880) capacity is 1620#
The weight of your trailer appears to be 4860 (9740-4880).
So you have left out one important rating: GCWR
What you can tow = GCWR - 4860
Assuming you meet the GCWR requirement (Please post your result) I also concur that the WDH settings look ok as is....
6,500 lb GVWR
1,270 lb payload
4,880 lb curb weight with a full gas tank
3,200 lb front & 3,700 lb rear GAWR
9,740 lb combined weight of the TV and TT, fully loaded with WDH and gas tank 1/3 full per CAT scale
2,620 lb front, 3060 lb rear & 4,060 lb TT per CAT scale
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
