lawrosa
Jul 05, 2014Explorer
Yes I guess its right. the tongue calculated to 800 lbs.
I would still take that 80lbs off the front axle. Only restore to oringinal weight with truck only.
If you go by you axle ratings you limit is 6900 lbs. So your capacity is 2020 lbs
Your truck with trailer is 5680 lbs
If you go by gvwr of 6500lbs you have another 820 lbs you can haul in the jeep.. If you go by axle rating another 1220 lbs...
Wow that jeep is pretty capable. What motor do you have? How does it pull? What transmission temps you run when pulling?
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
