rk911
Aug 25, 2014Explorer
susanka wrote:
Thank you so much. I guess I'd better put all those pots and pans in the darn thing and ask DH to take it to the scales. And make sure we have the correct weight with a toad. Too bad, I really liked the CR-V, but I bet it won't work.
Susan
again, the CR-V won't add to the weight OF the MH, just the amount of weight the MH can pull. be sure to get separate axle weights on the MH and then compare to the gross axle weight ratings. also detrermine if you have a Class II hitch (3500-lb rating) or a Class III (5000-lb rating).
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
