- campiglooExplorerI think you would be ok with that. Just keep in mind, when they get ready to upgrade, the truck will probably need to get upgraded as well.
- pappcamExplorer
Old Days wrote:
The reason I say that, my TC loaded weighs about 1800 pounds and when I pull my 2000 pound boat my half ton truck struggles climbing the steep hills by my house. My next truck will be a GMC 2500.
I see. A TC is a little too much for any half-ton in my opinion. There's not enough payload capacity. My half-ton pulls my TT just fine and I travel with it in the 6200 pound range. I'v pulled some steep grades as well and kept my speed just fine. - brireneExplorer
pappcam wrote:
A 6500 GVRW trailer is a good match for a half-ton unless the half-ton has no towing package or a standard V6.
x2 - Old_DaysExplorer IIThe reason I say that, my TC loaded weighs about 1800 pounds and when I pull my 2000 pound boat my half ton truck struggles climbing the steep hills by my house. My next truck will be a GMC 2500.
- pappcamExplorer
Old Days wrote:
I own a 2007 GMC Sierra 1500 with a 5.3 liter engine,and wouldn't even think of pulling that much weight. You need a bigger truck.
You're kidding, right?
A 6500 GVRW trailer is a good match for a half-ton unless the half-ton has no towing package or a standard V6. - Ron_GratzExplorer
3LittleDucks wrote:
Your friends need to go through a process similar to the following:
I'm helping a friend trailer shop, they will be towing with a F150 4x2, rated at 9600lbs. Will soon be a family of 5.
They're looking at 25-26' trailers, dry around 4500, gvwr around 6500. Too much?
1) Estimate how much the TT will weigh when loaded for camping.
For example, a TT which is 4500# "dry" might have a loaded weight of 5500#.
2) Estimate the TT's loaded tongue weight which should be around 13% of the TT's loaded weight.
For example, a 5500# TT might have a TW of about 700#.
When using a properly sized and properly adjusted WDH, the vertical load transferred to the TV will be equal to about 75-85% of TW, depending on how much load gets transferred to the TT's axles.
Lets assume the TT-induced load is 550#.
3) Look at the TIRE AND LOADING INFORMATION sticker on the driver's door edge or pillar.
Find the maximum allowable weight for Occupants and Cargo.
Subtract the estimated TT-induced load from the TV's max allowable payload.
The remainder is the amount of payload capacity available for weight of occupants, items added to TV after delivery, cargo carried in/on TV, plus about 100# for the WDH.
4) Your friends will have to decide if the remaining payload capacity is great enough to meet their needs.
Ron - Gonzo42ExplorerActually, isn't that the answer to every question? A bigger truck?
- Old_DaysExplorer III own a 2007 GMC Sierra 1500 with a 5.3 liter engine,and wouldn't even think of pulling that much weight. You need a bigger truck.
- MvanderExplorerDepends on the f150. There are many many configurations from axle ratings to gvwrs. Need more info to make a call.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 30, 2025
