- joe_julie81ExplorerExcellent, Ed, my son is actually taking delivery on a new 2019 Civic sadan 6spd tomorrow. I'll check in his owners' manual to confirm it matches what you posted. I feel sure it will. I knew an automatic and cvt were out of the question. I'm hoping someone is out there using one this wau with some miles of proof behind them. Thanks
- Ed_GeeExplorer III found the definitive word from Honda in their 2019 6 speed Jan 2019 Owners Manual:
....and it wasn't easy ! .....
Honda
Towing Behind A Motorhome
Models with continuously variable transmission
Your vehicle is not designed to be towed behind a motorhome. If your vehicle needs to be towed in an emergency, refer to Emergency Towing.
Improper towing such as towing behind a motorhome or other motor vehicle can damage the transmission.
Models with manual transmission
Your vehicle can be towed behind a motorhome. Perform the following procedure before towing your vehicle:
Shift to Neutral.
Release the parking brake.
Turn the ignition switch (or power mode) to ACCESSORY. Make sure the steering wheel does not lock.
Turn off all electrical devices. Do not use any accessory power sockets. This can prevent the battery from running down. - Ed_GeeExplorer II
enblethen wrote:
What does the owner's manual say?
Page 431 says no recreational towing.
2019 Owner's manual
That is not the manual for the 6 speed turbo manual transmission..... - 2oldmanExplorer IIYour sedan owner's manual should have that.
- Ed_GeeExplorer IIAccording to the Good Sam tow guide, yes.Good Sam 2019 dinghy tow guide
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
