mowin's avatar
mowin
cant get TV in master to work..
Cant get my tv in the master to work. I'm using the antenna,and I got the tv in the lr to work. Any ideas? The button for cable/attenna is in the master, and no matter if is on or off I can't get the tv to recognize any channels.
  • New to us FW. The tv was in our previous tt and worked fine. I tried scanning for channels several times.
    Seeing the button for cable/antenna in in the master, does that mean the coax goes to the master first than to the lr? If so does that eliminate loose connections inside the walls as the tv in the lr works fine?
  • Has it ever worked? No, could mean cables connected up wrong.
    Yes, could indicate that the TV settings are incorrect. Verify input, then scan for channels.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
