MetalGator's avatar
Feb 04, 2018
Carbon monoxide detector going off
Last night in our motorhome the carbon monoxide detect kept going off. I opened all the windows and vents and kept hitting reset but after a few minutes it would go off again. This went on for about 30-40 minutes. I finally dismounted the detector and held it up to an open window. Just as I was about to start cutting wires to shut it down, the red light went out and it quit beeping. I am trying to figure out what caused this. We are parked on a lake with other RVers. I did have a fire going outside before the alarm went off. I got up and closed the door (just had the screen door closed) at one point because I was starting to smell the camp fire a bit inside. Could this have caused the detector to go off? I have had issues with the propane detector going off in the past when the wife put on perfume but I have never had the issue with the carbon monoxide detector.
Burch
  • It should have a date on it. Even though it is a new motorhome I would check it. May be old stock they had sitting around. Mine did that with the beeping but it was old.
  • As you pointed out these sensors are super sensitive and will alarm with very little provation. I would suggest that it probably was your campfire smoke that caused the alarm. However I just replaced one in my TC that was only 2 years old. I've not only replaced the original but also installed a second battery operated unit as well. Better safe than sorry!
  • donn0128 wrote:
    They age out. The mfg will say 5 years, but I have lost them in less than a year.
    The motorhome is brand new. 2018 Miramar. I would hope they would last longer than that but who knows how long the detector has been sitting on a shelf before it was installed.
    x2
  • They age out. The mfg will say 5 years, but I have lost them in less than a year.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
