DAS26miles's avatar
DAS26miles
Explorer II
Nov 04, 2016
Carry chains- Travel Trailer and Class A Question???
My friends, one has a small pick and ultra-lite TT and the other with a 32ft Class A. We want to go to Yosemite in the coming months and the Park states that you must carry tire chains. I have been up there many times with my Class C and I have chains and only put them on once. Never again. Will wait it out until roads clear.
Question, what should my friends do, buy chains? Do they even make a set for the 19" Class A's. And what would the friend with the TT have to do? We will all just wait it out and never put them on.
  • I bought basic cable chains to fit my 19.5 wheels from an O'Riely auto parts store. I have yet to use them, but I put them on one day to make sure I know how to do it and to see how well they fit.
    I am fortunate to have independent hydraulic levellers so I can lift the back wheels off the ground.
  • This is California. Looks like chains are required for the Class A rear outer dual and inner if it can be done (clearance issue). The TT will need them on the TV rears and the TT axle with the brakes.
  • Wa state says for certain passes some times of the year we must CARRY chains, we never have had them on.
    But we gotem
  • As others have mentioned, most areas I've been to that have chain restrictions require you have chains for at least one drive axle on the tow vehicle, and one axle on the trailer. I hate driving with chains and avoid it as much as possible, although I do end up having them in the truck during winter months as they sometimes check that you have them even when you don't have to put them on.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    Tyler0215 wrote:
    You HAVE to carry chains if the law requires, even if you plan on waiting till the roads clear.
    The TV will need chains, not the TT.
    Someone makes the size you need. Call tire shops.
    depends on the location. Oregon requires chains on at least one axle of any trailer when chains are required on the tow vehicle. AKA drag chains.
    but, while I carry them, if it gets to that point we just wait it out. Just isn't worth it for us to chain up given the risks towing on roads that are that bad.
  • I have had to put them on our Class A and on our C, when we had that, up at Mammoth Ski Area.....I did not think it was to big of a deal as long as I wore my ski pants and jacket and laid on a piece of outdoor carpeting.
    Bought ours at Les Schwab Tire Stores.
  • We were able to rent a set of chains from our local equipment rental store.
  • If I am not mistaken, chains are required on an RV trailer axle that has brakes. Many auto stores will take unused chains back if not used.
  • You HAVE to carry chains if the law requires, even if you plan on waiting till the roads clear.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
