wowens79's avatar
wowens79
Explorer III
Sep 13, 2017
Caulking on trim
On my TT there is a piece of trim over the seem between the filon side, and the aluminum skirt. The caulk on that piece of trim has separated, and needs to be replaced. It is a clear caulk.
Can I use clear exterior door and window caulk?? I know you have to use dicor or eternabond on the roof, but on the side piece can I use regular caulk??
  • JimK-NY wrote:
    I wasted a lot of time and effort trying to use Geocel clear. I got tubes from different suppliers, years apart and tried to use the sealant as soon as I got it. The material did not seal or adhere properly. I believe both shipments had tubes of caulk that were too old.
    Were you trying to seal areas that had an original sealant applied?
  • I wasted a lot of time and effort trying to use Geocel clear. I got tubes from different suppliers, years apart and tried to use the sealant as soon as I got it. The material did not seal or adhere properly. I believe both shipments had tubes of caulk that were too old.
  • Geocel rv clear is a 20 year caulk. No fun to work with but better than others for durability.
  • search for a current thread on this, unless you are the same OP.
    bumpy
  • Thanks, its a 2016 Forest River Heritage Glen. I'd like to knock it our Saturday, so I'll have to drive a bit to a dealer.
    Dicor non leveling would work, but look like **** and not match the rest of the trailer. What brand trailer?
    A lot of Forest River products would be Geocel, either Proflex RV or 2300.
    A lot of Keystone products may be Tremco Trempro 644, a neutral cure silicone.
    You wont find those products at the big box or Ace, look online.
    The best part is they change what they use sometimes. Call or send an email to the manufacturer and ask them. That sometimes works, and sometimes they have not a clue what they used LOL.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
