rbreak
May 28, 2018Explorer
jplante4 wrote:
I just started towing an Equinox that is infamous for death wobble. I don't pull any fuses because I ran a charging line to the battery. I did notice that if you are in a turn and step on the gas, the wobble occurs. I think the trick is to ease out of the turns and don't put a side load on the toad.
Hello, not sure if this is common info yet or not, but the new instructions from GM on towing the equinox is to leave the fuse on the inside of the car in (fuse 32 I think) and instead pull fuse 16 from the fuse box in the engine bay. You already have the charge line which is another part of the new instructions. The fuse 16 supposedly has something to do with the steering returning to center after a turn. Might be worth a try.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
