LOFAT36's avatar
LOFAT36
Ceiling lights
2012 Crossroads Cruiser 5th wheel. The ceiling lights are I guess you'd call them pot lights. The covers are almost flat and they don't turn. How in heck do you get these things off ?
  • They don't slide or turn and there is nowhere to grip on to turn as the lenses are almost flat & flush with the mounting pod. I've tried a slot screwdriver but there isn't room to slide it in around the edges.
  • The covers on mine slide to the outside just a bit. It then lifts off easily.
  • Many of the covers are pushed on and pulled off. Of course, if you pull real hard and a cover breaks, then it must have a different method than I indicated. Some have springs or clips that hold it up. Once you pull out the trim a bit, you may see the clips - to be depressed.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
