hbillsmith
Jun 20, 2016Explorer
You can add an extended run tank using the Pinellas kit and a standard Yamaha connector outboard marine gas tank. The built in tank is 1.6 gallons good for 4 or 5 hours of A/C. I use a 6 gal. External tank that I share with my outboard. With the external tanks you can swap without worry about spilling gas on a hot genny and causing fire.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
