lafester
Jun 10, 2017Explorer
hbillsmith wrote:
Followup after 1-year:
My Champion 3100 still runs great after adding the Extended Run option. No leaks and engines runs great. As for new ideas, this season I ran about a gallon of gas with Seafoam mixed in to give it a nice clean up. I think that helped because unless its my imagination, I think the ole' 3100 is running even smoother now.
Just wanted to say THANK YOU for the great pdf lists and pictures.
I had no experience with marine quick connect parts and would have never figured it out on my own.
Cost was a big issue for me so I got the chinese knockoff fuel pump, filter and bulb hose with connections. I must say they all are working great so far. I have an extra pump, two extra filters, a few feet of fuel line, fuel cutoff valves and clamps and everything was still less then oem.
One of my brass connect fittings was faulty and just spewed fuel everywhere but amazon sent a new one right away with no hassle. Is there any way to fix the broken one? Also looking for a good way to cap these so dust doesn't get in there and clog them up when travelling.
The only thing that tripped me up was positioning the fuel pump. I had it centered when it really needs to be over away from the carb side so there is room to connect the hose off the t connect.
It was kind of fun setting it all up and hopefully after a year I will be back saying how great it still works.
