Mel_B_
Jun 21, 2017Explorer
So I ran it with gasoline and propane here are the results. On Gasoline I ran the 13500 A/C for one hour, it was in the 90's outside. one hour later it was 65 in the coach. I shut all down and refilled gas tank with a quart jar, it took 1 3/4 quarts of gasoline.
So I turned off the gasoline switch and ran all the fuel out of the carb. Then I hooked up a full 5 gallon propane tank. Started inverter pluged in 30a cord and started the A/C again ran fine for one hour. I shut down and went back to have the 5 Gal. tank refilled, 1.2 gallons. Kind of disapointing. Both test were done with the switch in the Economy ON.
It's a great little machine but I wish it would do better on the propane uage.
Mel
Mel
